Velocity Measurement Spikes on NI-9760 When Using Hall Mode
Updated Apr 10, 2018
  • NI-9760
When I am acquiring velocity measurements from my NI-9760 in Hall Mode (i.e. when zero crossing and internal threshold are configured to be false), I observe sporadic large spikes in my velocity measurement on one or more of my channels, as shown below:
Figure 1.  Velocity Measurement Spikes on NI-9760
This behavior is due to the susceptibility of the NI-9760 in Hall mode to noise, which results in occasional spikes in velocity when the NI-9760 counts a false pulse that has occurred due to noise in the system.
To resolve this issue, NI recommends using a debounce filter in the FPGA for any applications with the NI-9760 that require the use of Hall Mode.
You can find an example program, including both a conceptual explanation of the debounce filter as well as an example implementation in LabVIEW FPGA. See FPGA Digital Debounce Filter Reference Example for more information.
