The number of ethernet cDAQ chassis that can be chained together is dependent on the chassis and topology used for the application (
as explained here). For the cDAQ-9189 chassis, the maximum hops per line is 15, so you can daisy chain (line topology) up to 15 ethernet 9189 chassis together and synchronized them.
