How Do I Write my DAQ Data to a File After I Filter it?
Updated Aug 11, 2022
I am using DAQmx VI's to collect data in LabVIEW. I am currently using the "DAQmx configure logging" VI to write my data to a file but it doesn't let me filter my data before it writes it to a file. How could I filter my data before I write it to a file?
One way to accomplish this is to take the data output from the read and wire it into your filter. You can then wire the filtered data into a "write to measurement file". The picture below shows one way of doing this.
You might consider using a producer/consumer loop set up if you are trying to filter data at the same time that you are collecting it. The Producer/Consumer pattern gives you the ability to easily handle multiple processes at the same time while iterating at individual rates.
