TDMS Write Each Loop of Data in Separate Columns
Updated Nov 21, 2019
I would like to use TDMS functions to log my DAQmx data from one channel. However, for each loop I would like the data to be in a separate column. How can I do this?
TDMS writes separate columns as channels. In order for each loop to store the data in a separate column, you need to set the loop as the channel by either
  • Wiring the loop counter index to the channel name input of the TDMS Write function
  • Building an array of loop values and wire the build array function into the channel name input of the TDMS Write function
Note: These TDMS channels do not refer to the same channels on the hardware in which you are acquiring data.
