Which Digital Ground Pins Do I Use on The PCIe 6353?
Updated Apr 17, 2018
  • PCIe-6353
How do I know which digital ground pins(D GND) go to which digital outputs on the output block of the PCIe 6353?
The PCIe 6353 doesn't have isolated ground pins for each digital output. All of the D GND pins are connected meaning you can use any of them with any of the digital outputs.
