The wire mappings for the SHC68-68-RDIO and SHC68-C68-RDIO2 cables can be found below.
The wire list document for the SHC68-68-RDIO cable contains information such as shielded pairs and color codes. Note that all DGND lines are internally connected within the cable.
Group A of the SHC68-68-RDIO Cable
Group B of the SHC68-68-RDIO Cable
Group C of the SHC68-68-RDIO Cable
The wire mapping and shielding information for the SHC68-C68-RDIO2 cable can be found below. The ground lines are internally connected within the cable.
Note: The cable wire list includes both PIN # and PAD # columns. The PAD # values are internal cable construction details and do not correspond to the physical connector pin numbers. When comparing the cable documentation to the pinout of a compatible R Series device, use the PIN # column, as it corresponds to the physical pins on the VHDCI connector.
The SHC68-C68-RDIO2 cable is compatible with multiple products. As a result, the signal names shown in the cable wire list may include signals that are not used by every supported device. For device-specific signal assignments, refer to the pinout documentation of the connected R Series module.
Pins 1 to 34 of the
SHC68-C68-RDIO2 Cable
Pin 35 to 68 of the SHC68-C68-RDIO2 Cable
