Could Different DBC be Added to the Same CAN Port in VeriStand
Updated Apr 23, 2018
  • CAN Interface Device
  • VeriStand
  • NI-XNET
I want to add several different dbc files to one CAN port in VeriStand. How to realize this?
This feature could not get realized in VeriStand. When we created two CAN ports in VeriStand with the same CAN ports and different dbc selected in configuration, VeriStand would end up with an error. Which indicating different configuration could not be applied to the same source.
In VeriStand, only one dbc should be applied to one CAN port. As a result, if you want to use different dbc files, you must increase your CAN port number in this situation.
