Fatal Error of Missing Terminating Null in String Argument When using UDP Example in LabWindows™/CVI™
Updated Jun 6, 2018
  • LabWindows/CVI
Programming Language
  • C
Other
UDP
I'm using UDP example in LabWindows/CVI but I get an error in UDPReader.c file. The error happens in the errChk (SetCtrlVal(panelHandle, PANEL_TEXTBOX, msg)), the code is as below:
int CVICALLBACK UDPCallback (unsigned channel, int eventType, int errCode, void *callbackData)
    int error = 0,
        size;
    unsigned char  *msg = NULL;
    if (eventType == UDP_DATAREADY)
        char            srcAddr[16];
        unsigned int    srcPort;
        char            msgSourceString[16 + 10];
        errChk (size = UDPRead(channel, NULL, 0, UDP_DO_NOT_WAIT, NULL, NULL));
        nullChk (msg = malloc(size));
        errChk (size = UDPRead(channel, msg, size, UDP_DO_NOT_WAIT, &srcPort, srcAddr));
        sprintf(msgSourceString, "[%s:%d]: ", srcAddr, srcPort);
        errChk (SetCtrlVal(panelHandle, PANEL_TEXTBOX, msgSourceString));
        errChk (SetCtrlVal(panelHandle, PANEL_TEXTBOX, msg));
        errChk (SetCtrlVal(panelHandle, PANEL_TEXTBOX, "\n"));
Error:
    if (error < 0)
        MessagePopup("Error", GetGeneralErrorString(error));;
    if (msg)
        free(msg);
    return 0;
The error code is:
FATAL RUN-TIME ERROR: Missing terminating null in string argument.
This error means the string argument msg missing terminating null '\0'.
If the size of you UDP message is 'size', then you should malloc 'size+1' memory to allow the msg to contain '\0' :
    int error = 0,
        size;
        char            srcAddr[16];
        nullChk (msg = malloc(size+1));
        msg[size]='\0'
Error:
    if (error < 0)
    if (msg)
        free(msg);
    return 0;
