How to Delete Zeros and NoValues from DIAdem Channel
Updated May 4, 2023
  • DIAdem
I have several zeros or NoValues in one of my DIAdem channels. I would like to delete all of these values simultaneously. Is there a way to do this in DIAdem?
In order to remove all zeros or NoValues from a channel, use the ChnNovHandle command.
This command will also allow the user to interpolate the values to an equidistant value between the adjacent valid numbers rather than removing them.
