In order to use a VI in TestStand, follow these steps:
1. Add an
Action step to a sequence
2. With the
Action selected, choose the
Module tab in
Step Settings
3. Point to your VI using the VI Path field:
4. You can now see the connector pane and enter values for the inputs and outputs.
You can enter numbers or strings into the
Value field, or you can enter variable names. If you want to create a variable, you can type in a name, right-click the text-field, and choose "
Create "Locals.variable name" where
variable name is what you called your variable. There are other options as well such as creating the variable as a Parameter.
More information can be found in the
TestStand LabVIEW Adapter Help page
