You can disable this option from the TestStand Sequence Editor by completing the following steps.
From within the TestStand Sequence Editor, select Debug >> Sequence Analyzer >> Sequence Analyzer Options.![](/servlet/rtaImage?eid=ka0VU00000086Mn&feoid=00N3q00000HUsuI&refid=0EM0Z000000FQts)
When prompted with the following dialog box, disable the option Analyze File Before Executing and select OK to confirm.
![](/servlet/rtaImage?eid=ka0VU00000086Mn&feoid=00N3q00000HUsuI&refid=0EM0Z000000FQtx)
Disabling this option can be useful to avoid initial errors, for example if you are creating variables during the execution of your sequence file.
