Limited MathScript Functionality in LabVIEW Communication System Design Suite
Updated Apr 6, 2018
  • LabVIEW Communications System Design Suite
  • LabVIEW MathScript Module
  • LabVIEW Professional
  • LabVIEW NXG 1.0
I have noticed that not of all of the functions included in MathScript are accessible via the LabVIEW Communication System Design Suite. Can you explain?
National Instruments currently supports MathScript in the following software packages:
  • LabVIEW Full & Professional 8.0 - 8.6 (with LabVIEW MathScript)
  • LabVIEW Full & Professional 2009 - 2017 SP1 (with the MathScript RT Module)
  • LabVIEW NXG 1.0
  • LabVIEW Communications System Design Suite 1.0 - 2.0
MathScript Nodes support a large subset of the most commonly used functions and properties found in MATLAB. The supported functions for the MathScript Node in each of the listed software above can be found in the help documentation of respective software suite (see also Related Links below and browse to the MathScript Function Reference section).
