Replacement Power Supply for GPIB-RS232 Device
Updated Jun 14, 2018
  • GPIB-RS232
  • USB Digital I/O Power Supply
I want to replace the power supply for the GPIB-RS232 converter device I have. I can't find an orderable part number for the replacement.
The GPIB-RS232 device kit contains a 12V power supply and a power cable related to the region the power supply will be used in. The NI USB Digital I/O Power Supply contains the same power supply contained with the GPIB-RS232 device kit. It can be used as a replacement for the GPIB-RS232 power supply. Please ensure that you select the correct region before purchasing a replacement.
