ID Not Found with NI-9853 CANOpen LabVIEW FPGA Example
Updated Apr 19, 2018
  • NI-9853
  • CompactRIO Chassis
  • LabVIEW FPGA Module
I am using the CANOpen Reference Example for the NI-9853 C-Series CAN Module with my own CANOpen sensor. When I run the program, I don't receive any errors and am receiving data, but the 'ID Not Found' boolean lights up. Why is this happening, and how do I resolve it?
The 'ID Not Found' will light up if the program does not recognize your 'CAN LUT - Index' input. This is the address input to the 'CAN ID Index' Lookup Table. You must find the CAN address of your CANOpen sensor and enter that as the 'CAN LUT - Index'.
Your 'CAN LUT - ID' control is just the CAN channel you are using (0 or 1 on the 9853).
