How Can I Monitor a CAN, LIN, or FlexRay Bus Using NI-XNET?
Updated Jan 17, 2020
  • NI-XNET
I am using a NI-XNET device and I would like to monitor the traffic on the CAN Bus. Is there an utility to do it without programming in LabVIEW?
You can use the NI-XNET Bus Monitor that allows you to display and log CAN, LIN, or FlexRay network data.
This tool is automatically installed with the NI-XNET driver , to launch it you can use the NI-MAX or directly from your applications installed.
