Are the Ranges for the PXIe-4302 Channel Selectable?
Updated May 3, 2018
  • PXIe-4302
I would like to use some channels on my PXIe 4302 on the +/-10V input range, and use other channels with the +/- 100mV range.
Yes. Each channel has its own ADC, so the channels can be programmed to operate at different resolutions. To program, create a task for the device for each range and assign the correct channels.
