Stepper Motor Continues to Move With 0 Counts/s Velocity Command
Updated Apr 4, 2018
  • Motion Controller Device
  • NI-Motion
I am using a PCI motion controller card with a open-loop stepper motor. If I send a 0 velocity command to the controller, the motor will still move 1 step every 10-16 seconds.
Setting the load velocity to 0 counts/s or 0 revs/s is not a valid parameter. Use the Stop Motion command instead of overriding the velocity to stop the motor.
For more information about your motion controller's performance, please look at the Specifications section in your motion controller's user manual.
