Note: NI-DAQmx Base is compatible with macOS 10.14 and earlier versions – check
macOS compatibility for all supported versions for this driver. For more information, please read the
End-of-Life Announcement for DAQmx Base Driver .
Explanation of hardware names:The USB-9211 and USB-9215 consist of a either a C Series NI 9211 or NI 9215 module with a USB-9161 hardware carrier.
The USB-9211A and USB-9215A consist of a either a C Series NI 9211 or NI 9215 module with a USB-9162 hardware carrier.
The USB-9162 supports USB 2.0 Hi-Speed carrier, while the USB-9161 uses USB 2.0 Full Speed carrier.
The hardware carrier in use determines which driver(s) will support the USB-9211 / USB-9215 or USB-9211A / USB-9215A device.
Drivers:
Driver Support Table| |
NI-DAQmx
NI-DAQmx Base 2.x
NI-DAQmx Base 3.x (and later)
USB-9211
x
USB-9211A
x
x
USB-9215
x
USB-9215A, USB-9215A BNC
x
x
