Error -61330 When Compiling FPGA Code
Updated Oct 31, 2025
  • LabVIEW FPGA Module
  • FPGA Xilinx Compilation Tools
I am trying to compile an FPGA program and I am getting Error -61330. An internal software error in the compile worker has occurred.
In some cases this is also accompanied by other error messages like:
  • A BAD-MEM-POINTER error that pops up outside of the main compile window. After trying to compile 3-4 times it usually gets past that issue and successfully compiles the code.
  • Error 7
  • We were not able to zip the job's file correctly. Exit code: 1 Process: tar.exe
Here are some steps that you can try to resolve the issue:
  • Verify your code is code written in VHDL-93 or VHDL-2002 syntax. VHDL-2008 syntax is not supported.
  • Check that no firewalls or antivirus programs are blocking the compiler (the port that the compiler uses is 3582).
  • Run the Compile Worker with Administrator privileges.
  • If you are compiling locally on your computer, try using the Compile Cloud Service instead.
  • Review the compile worker log, this can give insight to what specifically is occurring within the worker. This can be accessed through your program file directory: \National Instruments\FPGA\CompileWorker\workerLog.txt.
  • Restore NI RT Target to Factory Default Configuration.
  • Repair or force reinstall the LabVIEW FPGA Module and/or LabVIEW FPGA Compilation Tools.
  • Make sure there is no white space in your windows username. Space in windows username will break the path to Windows temporary directory C:\Users\<YourUserName>\AppData\Local\Temp where the compiler saves temporary files.
  • Reinstall the NI Software in the following order:
  1.  LabVIEW
  2. LabVIEW Real Time Module
  3. LabVIEW FPGA Module
  4. LabVIEW FPGA Compilation Tool Vivado 2017.2
  5. NI Compact RIO Drivers
  • Format your PC's OS.
