For example, while you can have Run-Time Engines for LabVIEW 2015, 2016 and 2017 installed, you will not be able to install LabVIEW Run-Time Engine 2015 f3 if LabVIEW Run-Time Engine 2015 f5 has already been installed.
The below screenshot from NI MAX shows a full working software stack.
