The list below contains volatility information for the cDAQ-9171, cDAQ-9174, and cDAQ-9178. It includes the types of memory in each device, the amount, and whether or not the information stored in that memory is retained. Volatile memory loses its contents when the device is powered off, while nonvolatile memory retains its contents when the device is powered off.
The list below contains volatility information for the cDAQ-9172. It includes the types of memory in each device, the amount, and whether or not the information stored in that memory is retained. Volatile memory loses its contents when the device is powered off, while nonvolatile memory retains its contents when the device is powered off.
