You can incorporate
another cDAQ chassis into your system for more slots. If you are using a cDAQ with an embedded controller (cDAQ-913x series), you can connect a USB or Ethernet cDAQ directly to your cDAQ controller.
You can also opt for the 14-slot cDAQ-9179, which is National Instrument's largest slot chassis.
