Error 2228 When Running LabVIEW Executable
Updated Oct 8, 2018
  • LabVIEW Run-Time Engine
I built an executable. When I run this executable on a client machine, I get the following Error: VI has error type 2228: the full development version of LabVIEW is required to fix the error. How do I fix this?
One cause of this can be using incompatible versions of LabVIEW Run-Time.
When running an executable, you must have the same version of LabVIEW Run-Time as the version that the executable was developed on. If this Run-Time version is incompatible with your operating system, this error may appear.
To solve the error, you must either revert to a compatible operating system or upgrade the source code to a newer version of LabVIEW, rebuild the executable, and install the corresponding Run-Time version.
