TestStand and Semiconductor Module Version Matching
Updated Jun 15, 2018
  • TestStand
  • NI TestStand Semiconductor Module
Is it possible to install a version of the TestStand Semiconductor Module (TSM) into a different version of TestStand? For example, can I install TSM 2016 SP1 into TestStand 2017?
No, the TSM major version must match TestStand. You could install TSM 2016 SP1 into either TestStand 2016 or 2016 SP1, but not into a newer or older version of TestStand.
TSM relies on connecting to the TestStand engine in numerous ways which change from version to version. Further, TestStand types are often updated between versions, so TSM code would be built with different types than TestStand if the versions mismatch.
