On my computer I have installed LabVIEW and the appropriate drivers and modules for my myRIO. The USB connection is fine as the device shows up in the Measurement and Automation Explorer (MAX). But when I try to run any VI on it, one of the following errors is reported:
- The software you have selected is not compatible with the version of your embedded OS. Consult the documentation on the device for information on upgrading or downgrading the version of the embedded OS.
- This target is running a version of LabVIEW Real-Time that is different than the Real-Time Module software on the host computer. You can verify the version and reinstall the Real-Time software using Measurement & Automation Explorer.
- Access denied: This target is running a version of LabVIEW that is different than LabVIEW on the host computer. For Real-Time targets, you can verify the version and reinstall the Real-Time software using MAX.
How do I solve this?
