Save a 3D Scatter Graph as a .DAE File
Updated Apr 23, 2018
I'm currently trying to save a 3D Scatter Graph as a .dae file so it cant be viewed using a 3D file viewer. I have been able to represent my graph as a Scene or a 3D picture however I cannot use the 'Scene. Write Scene File' Invoke node to generate a readable file using either of these.
You can generate a .dae file with the 'Scene. Write Scene File' Invoke node but this is not a method associated with the 3D Scatter Graph object. Outputting a .dae file is possible from a 3D Picture which is a less specific object. There is a workaround for this as shown in the example below.
