The I/O connector signal descriptions can be found in the help file for the specific series of card.
I/O Connector Signal Description Locations:
Common Signal Name Definitions: Please refer to following table.
SIGNAL
Description
AI_SENSE
In NRSE mode, the reference for each Analog Input signal is AI SENSE.
PFI
Programmable Function Interface - Each of these terminals can be individually configured as a PFI terminal or a digital I/O terminal. As an input, each PFI terminal can be used to supply an external source for AI, AO, DI, and DO timing signals or counter/timer inputs. As a PFI output, you can route many different internal AI, AO, DI, or DO timing signals to each PFI terminal. You also can route the counter/timer outputs to each PFI terminal.
AO_SAMP_CLK
As an output, this pin emits the ao/SampleClock signal. A high-to-low transition of this signal indicates a new sample is being generated.
FREQ_OUT
Frequency Output Signal—This output is from the frequency generator.
EXT_STROBE
This pin is used to control some NI accessories. EXT STROBE is an output-only signal that generates either a single pulse or a sequence of eight pulses in the hardware-strobe mode. An external device can use this signal to latch signals or to trigger events.
