NI 9185 or 9189 Shows Up as Unsupported in NI MAX
Updated Dec 28, 2023
  • cDAQ-9189
  • cDAQ-9185
  • NI-DAQmx 17.1
I recently upgraded to the NI 9185/9189. When I set up the device, NI MAX says the device is unsupported.
You will need to upgrade to NI-DAQmx 17.1 or later.
  1. Check the NI-DAQmx driver currently installed .
  2. Refer to NI-DAQmx and LabVIEW Compatibility to see if the current LabVIEW version installed is compatible.
  3. If the current version of LabVIEW is compatible, install NI-DAQmx 17.1.
  4. If the current version of LabVIEW is not compatible, upgrade first to LabVIEW 2014 or later before installing NI-DAQmx 17.1.
