Web Publishing Tool Worked In Previous LabVIEW Version But After Upgrade Front Panel Doesn't Show
Updated May 16, 2018
My VI that uses the Web Publishing Tool has stopped working after upgrading my LabVIEW versions.  It displays the text of the VI properly, but the Front Panel is not showing correctly.
This is most likely an issue with the ActiveX DLL not publishing the Front Panel correctly so make sure to enable all Add-Ons within Internet Explorer.  The ActiveX DLL is located at "C:\Program Files (x86)\Internet Explorer\Plugins\" so you must make sure that this is able to be run.
This could also be an issue with the allowed websites within Internet Explorer so make sure that the website is added to the Compatibility View Settings as well:
