Can I Use a Longer Cable For My CompactRIO's Mini-Display Port Than The Ones Provided By National Instruments?
Updated May 16, 2018
  • CompactRIO Controller
I need a Mini-Display port cable that is longer than the ones National Instruments provides.  What should I do?
National Instruments sells 1/2, 1, 2 M length cables but you may purchase a 3rd party cable that is longer. However, the tests of the CompactRIO's display port are performed with the supported cables so performance is not guaranteed with the 3rd party cables.
