Can I merge CAN database using LabVIEW?
Updated May 18, 2018
  • NI-XNET
I would like to merge two CAN databases using LabVIEW. How can I merge them?
NI-XNET driver provides database API which can edit the database. You can find the XNET API in the following path in LabVIEW palette: Measurement I/O>> XNET >> Database.
And you can merge two databases using XNET Database merge.vi like below figure 1. It also provides various merge method like Cluster and Frame merge. So you can select what you want.
Figure 1. XNET Database Merge.vi
