Using DAQ Device to Write Data to Multi-channels
Updated Jul 10, 2018
  • PCIe-6363
  • Traditional NI-DAQ
I have a PCIe-6363, how can I write data to multi-channels.
You can use the DAQmx example in the LabVIEW, Help>>Find Examples>>Hardware Input and Output>>DAQmx>>Analog Output>>Voltage – Continuous Output.vi.  When you choose the physical channels on the front panel, you can click Browse...>> Ctrl + Left button to choose multi-channels>> Click OK.  You can use the channels that you select, and make sure you add the number of waveforms are equal to the number of channels.
