Error -1074388957 When Using NI Automotive Diagnostic Command Set
Updated Mar 29, 2023
  • PXI-8513
  • PXI-8513/2
  • Automotive Diagnostic Command Set Toolkit
  • NI-CAN
  • NI-XNET
I'm currently trying to transmit CAN data using the NI Automotive Diagnostic Command Set (ADCS) and am running into error -1074388957. I can see my device in NI MAX and was able to transmit/receive data using the bus monitor, but cannot transmit/receive in LabVIEW using the example program from the ADCS.
Install the compatibility layer between NI-XNET and NI-CAN. Follow the Migrating NI-CAN Applications to NI-XNET  document for determining installation order. Keep in mind the NI-XNET Compatibility Library for NI-CAN isn't enabled to be installed by default.
