Can I Use NI Preselector 5693 as a Standalone Device?
Updated Apr 3, 2018
  • PXIe-5668
  • PXIe-5840
  • PXIe-5693
  • LabVIEW 2017 Full
  • NI-RFSA 17.0
NI 5693 is generally coupled with NI 5667 VSA. But, I want to take advantage of Preselector's FM band stop filters using NI 5840 (VST 2nd gen) or NI 5668R.  For this, I am trying to use NI 5667 with NI-RFSA drivers. I am opening a separate session and configuring the filters but no effect can be seen.
How can I configure NI 5693 to work as standalone device without NI 5667?
NI-5693 can be used as a standalone without being part of the NI 5667.  Please follow the below sequence to configure and use NI-5693 preselector as "Standalone":
For activation of any bandpass filter  (and corresponding bandstop filter), please select the concerned center frequency. NI 5668R and NI 5840  (VST 2nd gen) are wide band devices.  Using a bandpass preselector will limit the wide bandwidth of these analyzer.
