Deleting Entire Groups in the Data Portal
Updated Apr 10, 2018
  • DIAdem
I am using ActiveX in LabVIEW to call DIAdem commands. How can I delete an entire group from my Data Portal?
Use the command GroupDel(1)where 1 is the index of the group.
If you want to delete all of the groups in the data portal you can also use the command DataDelAll, so you will not have to index through all of the groups.
If you want to delete only a single channel in the group, you can use the command ChnDel("Group/SourceChannel")
