Is There MQTT Support for LabWindows™/CVI™?
Updated Jun 5, 2018
  • LabWindows/CVI
Other
MQTT
I need to add support for Message Queuing Telemetry Transport (MQTT) in my LabWindows™/CVI™ application. Are there any plans to add a MQTT library to LabWindows/CVI or can you tell me how to add an MQTT library to LabWindows/CVI?
Unfortunately, there isn't a native way to add MQTT library support to LabWindows/CVI, but it may be possible to just integrate it into your C code. LabWindows/CVI just provides its own C compiler, and while MQTT is not directly supported by us, it is certainly possible. You may also have luck with calling DLLs from the library
If you feel strongly about adding MQTT support to LabWindows/CVI feel free to post it to the LabWindows/CVI Idea Exchange, which is monitored by R&D. Other customers can comment and upvote your post for increased visibility.
