PCI Card Shows Up as PXI System Unidentified in NI MAX
Updated Apr 9, 2018
  • PCI-6221
I've connected a PCI card to my computer, and it shows up as expected in the Windows Device Manager. However, it shows up as PXI System (Unidentified) in NI MAX. Why is this happening?
This issue may be caused by incompatible software. Verify that DAQmx is compatible with your current Operating System. If the version of DAQmx is compatible with your computer, perform the following: If none of those steps work, contact NI support
