Can the NI-9467 Change Position During Operation?
Updated Mar 25, 2019
  • NI-9467
I'm planning on using the NI-9467 as part of a project that will have the module constantly changing its location. Can I use the module for this application?
No, the NI-9467 only supports stationary operation. Accurate GPS location and time data is generated from the self-survey period where the device averages location readings together to get a more accurate reading. This is a physical limitation of the device, anytime the device is moved a considerable amount, it must perform a location fix and restarts the self-survey period.
