Multisim features two different simulation models for device pins: an
Ideal Pin model for faster simulation results and a
Real pin model for more accurate simulation results. With the former option Multisim uses
Vcc/2 as switching level for all inputs. Set to the latter it uses the realistic switching levels.
You can find this setting in the menu
Simulate »
Mixed-mode simulation settings:
