Multisim Simulation of TTL Level Switching Logic Behaves like 5V CMOS
Updated Mar 15, 2023
  • Multisim
I added a Tiny Logic NC7ST04_5V to my Multisim schematic. This is a CMOS device with TTL-compatible inputs, specified to interpret an input voltage <0.8 V as low and >2.0 V as high. In reality, however, these devices switch at about 1.5 V.
When I place a supposedly TTL-compatible chip in Multisim I expect it to switch at the "correct" voltage of 1.5 V. However, the device switches at Vcc/2 which is 2.5 V. It behaves just like a regular 5 V CMOS part which gives wrong results for input signals between 2.0 V and 2.5 V!
Multisim features two different simulation models for device pins: an Ideal Pin model for faster simulation results and a Real pin model for more accurate simulation results. With the former option Multisim uses Vcc/2 as switching level for all inputs. Set to the latter it uses the realistic switching levels.
You can find this setting in the menu Simulate » Mixed-mode simulation settings:
When using Real pin mode make sure to have the proper power rails on the circuit. It's not always the same for each component. One can see which one(s) a component needs in the Pins tab of the component properties:
