Can I Set my DAQmx Timing Configuration Before Selecting a Physical Channel?
Updated Apr 9, 2018
Am I able to set the timing before creating the channel for my DAQmx task?
You cannot set timing for a DAQmx channel that hasn't been created yet in LabVIEW using the general DAQmx task flow (you can see this task flow under the 'Configure Task Timing in LabVIEW' section of this document).
You can work around this by keeping all the configuration data for your DAQmx task in a lookup table in memory and configure/start the task at the end.
