Can Multiple Channels on My DAQmx Task Have Different Timing Configurations?
Updated Apr 9, 2018
  • PXI-6289
I have multiple channels on the same DAQmx task. Can I set different timing configurations for each channel?
No, you can only set one timing configuration per task for each DAQmx channel. You can, however, follow the steps in this article to sample channels at different rates.
