Enabling the NI 4610 Output in NI MAX
Updated Apr 26, 2018
  • PXIe-4610
I have the PXIe-4610 power amplifier and I would like to configure it inside of NI MAX to amplify the signals I input into the card. How do I do this?
Below are the steps for configuring the PXIe-4610 in NI MAX:
  1. In the Configuration pane, expand Devices and Interfaces to see a the list of installed devices. Installed devices appear under the name of their associated chassis.
  2. Expand your Chassis.
  3. Select the PXIe-4610.
  4. Click the Power Amplifier Configuration tab.
  5. Select the Amplified 10X option button for each channel you want to enable.
With the PXIe 4610 there is no need for you to create a task to enable its output terminals.
For more details on the PXIe 4610 please refer to the Getting Started Guide and the Device Specification Sheet.
