According to the
P7000 manual, a green blinking status LED indicates that the ENABLE line is active, disabling the amplifier. To resolve this, switch the ENABLE line (either to ACTIVE OPEN or to ACTIVE CLOSED, depending on which one isn't currently selected) using the
P7000 tools, or just assert a LOW signal to the ENABLE lines on your P7000.
