Using TB-2706 With X Series Module NI-63XX
Updated Jun 29, 2018
  • PXIe-6341
  • TB-2706
I would like to connect my X series daq device PXIe-6341 to the TB-2706.
However, on the TB-2706 installation guide it said "PXI/PXIe Terminal Block for M Series and NI 6143 Devices".
Does the TB-2706 support X series device?
The answer is Yes.
You can based on the pinout label for M Series of the TB-2706 installation guide (figure 2).
Comparing this pinout with the NI PCIe/PXIe-6341 pinout, you will see they have the same pinout.
