NI-DAQmx Application Doesn't Work Correctly On Target PC
Updated Apr 24, 2018
I developed a LabWindows/CVI application using NI-DAQmx driver to acquire data from a CompactDAQ system. The application works fine on the development computer while it doesn't return expected data when deployed on a target computer.
The development and target computer have two different versions of NI-DAQmx driver.
NI-DAQmx versions installed on the development computer and on the target computer should be the same in order to have the application work as expected.
