Include a Dll When Deploying a Teststand Workspace
Updated Apr 6, 2018
  • TestStand
I would like to deploy a TestStand workspace that utilizes a DLL or library file. However when I use the deployment utility, it does not include the library file.
You must include the files in the Workspace that you deploy.
1. Rightclick your project in the workspace
2. Click add files to project
3. Select the file
4. Click add
5. Select the file path type
6. Click ok
8. Save the workspace File>>Save (ensure workspace tab is selected)
9. Deploy your application
Now under the deployment utility, all the libraries should show.
