Locating your LabVIEW's Serial Number Through the Windows File Explorer
Updated Oct 20, 2025
  • My computer won’t boot, and I need to recover the LabVIEW license from its hard drive using another system. Where can I find the license or serial number in the file system?
  • I misplaced the physical media for the LabVIEW installed on my computer. Where can I access the serial number on my PC?
  • Is my LabVIEW serial number stored somewhere on my computer's hard disk?
You can retrieve the LabVIEW serial number from where it is stored inside the LabVIEW ADE configuration .ini file.
  1. Find the LabVIEW ADE configuration .ini file, located in the path specified for your operating system:
    • Windows XP: <Documents and Settings>\All Users\Application Data\National Instruments\LVProductDLLInfo\<version>\LabVIEW_ADE_<version>
    • Windows Vista/7/10: <ProgramData>\National Instruments\LVProductDLLInfo\<version>\LabVIEW_ADE_<version>
      • To access the ProgramData folder, you will need to enable the "Show hidden files" option. Navigate to Start >> Control Panel >> Folder Options >> Views >> Files and Folders >> Hidden files and folders, select the Show hidden files, folders and drives option.
  2. Open the .ini file using a text editor. You will find the Serial Number under "SerialNo" key, "LicenseInfo" section, as long as you have previously activated your LabVIEW using the serial number.
The suggested way of retrieving serial number of LabVIEW is only applicable to LabVIEW. You will not able to retrieve the serial number of other NI software, e.g. TestStand, in the similar way.
Per NI Software Policies and NI General Purpose Software License Agreement, for Single-Seat user, you are allowed to retrieve the serial number and use it to activate LabVIEW on another computer.
