Can I Change C-Series Module Configuration Properties programmatically In LabVIEW FPGA?
Updated Apr 16, 2018
  • CompactRIO Controller
  • LabVIEW FPGA Module
I want to modify my C-Series module under my real-time controller's FPGA target properties in LabVIEW FPGA programmatically. How can I do this?
Each C-Series module has it's own set of properties that can be configured programmatically by following our help document on Setting and Retrieving Properties on FPGA I/O and FPGA Targets (FPGA Module).
In addition, you can view more properties and methods related to the I/O nodes of your modules by wiring a FPGA I/O reference from your I/O node to an FPGA I/O property node or method node
Not all module properties that can be configured in the LabVIEW project explorer will be able to be configured programmatically in LabVIEW FPGA.
