Programmatically Set System Mappings For Veristand Using LabVIEW API
Updated Sep 10, 2018
  • VeriStand
Can I programmatically map channels in VeriStand using VeriStand API in LabVIEW?
I am trying to make a VI that would map the system channels for me inside of a Veristand system definition file. I have quite a few mappings to make and many of the port names are repetitive
Yas, you can.
Below, you can found an example of implementation of that.
This example works with VeriStand project example located in C:\Users\Public\Documents\National Instruments\NI VeriStand 2017\Projects\Example
